4 Point Seatbelt Anchoring - Where?
I saw there was a thread similar to this but I didn't see anything conclusive on it. Unfotunately/fortunately I bought my Arntz 99% assembled and really don't want to take it apart to find out where I can locate the upper seat belt ties/straps for a 4 point harness. I have noticed from inside the trunk/boot that there is a enlarged/thickened area that spans across the entire back panel. I don't know if there is steel in/around there or it is just a fiberglass build up for rigidity of that panel. The interior is installed and I am fairly tall 6-2 I have the seats placed baiscally as far back as they will go making the space between teh back panel the the back of the seat fairly small. SO is there steel to anchor the belts in there or do I have to add steel or make a hole in the rear bulkhead panel to run the belts through and into the frame in the rear/trunk? Thanks for any info from the experts. next will be Q's on installing the roll bar..... stay tuned.
