Old 11-02-2011, 07:35 PM
bobcowan's Avatar
bobcowan bobcowan is offline
I made a mounting plate from 1/8" plate alum. I bolted that to the front X-brace of the frame. I bolted two T-clamps from Summit Racing to the plates, so they hold the Accusump about 1/2" from the ends. If you put the T-clamps closer together, you can bend the tube and then it doesn't work any more. Then all you have is a dead space filled with oil - not very helpfull.
Since this picture was taken, the green electric valve failed and I removed it. If you're racing, I do not recommend the electric valve. Of course, if you're not racing, why install the Accusump in the first place?
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
