Old 11-03-2011, 04:50 AM
"Q"'s Avatar
"Q" "Q" is offline
Cobra Make, Engine: 383 Stroked and Blown Chevy powered Cobra
Deoxidine rust remover (purchased at local hardware store) worked wonders for me to remove the heavy yellow heat discoloring on the stainless side pipes. Using a rag, applied it to cold side pipes, waited an hour or so, rinsed with water and allowed to dry. A light polish with a metal polish brought back the original finish again.
PS. Did a test with hot side pipes. Again using a cotton cloth (make sure the cloth is not made from a material that will melt) soaked with Deoxidine. Basically wiped the yellow off on contact (heat works as a accelerant). Beware of fumes and possible burns from the hot pipes!
PSS. Different degrees of success have been obtained with different grades of stainless, so it is advised to first do a test on a obscure piece of the side pipe.
