11-03-2011, 05:09 PM
GA
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Front Suspension
Originally Posted by strictlypersonl
Judging by the welds on the front upper control arm, I'd be hesitant to drive that thing out of the garage...
Should you ever decide to rectify the IFS you are in luck as a bolt on alternative for the MGB IFS exists. It is from a company called Fast Cars in Michigan.
It is far superior in quality and about 80lbs lighter than the original MGB. From a cost standpoint it would be very comparable. I totally rebuilt an MGB IFS for my Butler and the cost was almost the same.
Good luck with your toy.
Arthur
