4SECA Sorry I don't have a diag camera. Mine is under the car. I have had to add a shield to protect the tank from debries that come off the front tires. Same as everyone else for tapping in to the
oil line. Have the electric valve and 30 psi of pressure coming out of the tank. Someone just released a new valve setup for controlled oiling from the tank. It's automatic when the pressure drops below a psi range it automatic balances out the pressure. Also works to slow down the refill of the tank and not hurt the motor from not getting enough
oil back into the tank. New stuff I just fopund. Canton, Milidon, or one of those companies. The only reason I didn't mount my tank under the hood was because or room and location. I have seen thses tanks mounted on the frame cross bar. It's 20 pounds of high weight in the car. Doesn't sound like alot but being able to keep weight low in car is better. The other reason is air flow over the motor and not blocking any thing in back of the coolant fan. Rick L.
