  #38 (permalink)
Old 11-04-2011, 07:51 PM
Cashburn's Avatar
Cashburn Cashburn is offline
Backdraft Racing Dealer
Originally Posted by twobjshelbys View Post
I overstated. From a copy of the original invoice
RESF-427IR-C 427IR- 427 cu. in. Fuel injected 8-Stack engine Package includes Air Cleaner, "Weber Style" 8-stack induction system, (Engine is controlled utilizing a "Roush Calibration"), Engine control unit w/Harness, dual syn cdistributor, electric "High Volume" fuel Pump, Wide Band O2 sensor, intake air temp, sensor engine coolant sensor, MAP sensor, IAC (Idle Air Control), and ignotion control box, 36 Lb./Hr Fuel injectors and fuel pressure regulator. Also includes spark plug wires and custom looms, water pump, alternator, pulleys, w/bracket and spacers, fan belt, Roush valve covers, 8qt. Roush front sump baffled oil pan w/dipstick, flywheel, starter and cable, melling adjustable high output oil pump and "Hot Test" w/dyno documentation
Price for tne engine was $22,500
2-piece integrate loom valve cover with Shelby Logo $850
Total: 23,350
This was ordered 10/12/2006.
Don't forget freight.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
