How often do you change your brake fluid?
How often do you change your brake fluid? My ATE brake fluid is going on 3 years. I tested it with a Phoenix test strip that tests for copper content and it came out white. The chart says to change the fluid if it turns purple. If you have ABS brakes you should change it every 2 to 3 years to prevent rust in the lines.
 Snakebit
