Old 11-05-2011, 09:17 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Depends on what you use the car for, and what kind of brake fluid you have.
If the car is a street cruiser and doesn't see that many road miles, and you used a standard DoT4 fluid, changing every 3-4 years is more than enough. How often do you change the fluid in your DD?
If you were silly enough to use a DoT5 silicone fluid, it should be changed every 1-2 years. More if you live in a damp climate.
If your engine compartment gets hot enough to degrade brake fluid, you have a serious problem.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
