Hey everybody,
I didn't know whether to post this in here or the technical section but I figured some of you Kirkham owners must have dealt with this before.
My EFI system, the FAST EZ-EFI set up, requires connecting a fuel pump wire from the ECU harness, to the car's fuel pump relay.
I have found the relay and which side it is supposed to go in but my question is more towards how I should do it.... Do I just put the EFI wire into the same connector as that 85 wire is already plugged in? Do I tap into that 85 wire? Do I remove the 85 wire? Right now it is hooked up to be usually manually with dash mounted switch.
Let me know if my question is not very clear, maybe I can explain it a different way.
Thanks!
