Originally Posted by Tom Kirkham
Your build is looking good.
Two issues:
The thin plastic inner liner on the braided stainless steel fuel hose is Teflon. The fuel line we supply is rated over 500+ PSI. The rubber lined hoses break down with alcohol. The rubber hoses are also permeable to gasoline.
From the school of hard knocks, we have learned, the rubber hoses will slide off polished radiator tubes. You will need to sandblast the end of the tube that the hose covers up, to provide enough friction for the hose to stay on.
Its info like this that keeps me coming back to this site...
I would only have learned that the hard way!
So many thanks!
Avmaviator - Great work. Keep it coming... I'm loving it!
So many thanks to you also
