Originally Posted by tcrist
John,
Think of it in the same way.
Build a frame that will pick up in the middle using the A frame or forklift, with four adjustable legs that line up with the fenders. Then make some over bent brackets that will attach to the finder lips. Make the brackets large enough that you can put some cushioning between the brackets and the fenders.
You might even want extra pickup points in the door areas just for a little extra stress relief.
I can sketch you up something if I am not explaining it very well.
Terry, I was sort of thinking about making a spreader type rectangular lifting frame and picking from a central point. My problem with that would be finding balance center for the 4 lifting points at the fenders. I'm trying not to redesign the wheel, and make the real project working on the car. Maybe you could whip me up a little cartoon drawing of what your thinking?
Thanks John
