Old 11-11-2011, 06:12 PM
Keithc8 Keithc8 is offline
Like mentioned above it appears that they used non hardened pushrods, they wore and then it bent. You will have to replace the pushrods and then run through the valves and set them. You would want to change the oil and filter as well as this metal would have gotten into the oil.
I think that doing this will solve your problems and then you could re-adjust the carb as needed.
Good luck, Keith
Keith C
