Thread: 600ci Ford FE
Old 11-16-2011, 04:22 AM
Default Talk to Jay Brown
fordracing65 Jay is the guy to talk to. He is working on a couple of project. Your problem will be a dry block. Might have to run alcohol to drive this or E-85 fuel for starting. The question is why?? FE block is a 4.440 on center bore line. You can buyild off set cylinders with alot of money for boring out a block. Everything will be custom. Motor could cost in the 30-40K range. Why not build a Cammer for a GT-40 from a 527 shelby block. Believe me you will have more power that your car can handle. FI system or even go blown or turbo system if you are looking for top end power. Kirkham can mill you a custom block for 600 cubes, Problem may be heads lining up with wide bores. If you want a large motor, go GM with a 572 or 640 motor. They are built on 5.0" bores and up. Rick L.
