Dash fabrication, I elected the drop-down style for the switches.
First test fit, the angle is perpendicular to the steering column/wheel.
These are the tabs which hold the dash board.
There are 8 mounting points for the dash.
Brake-fluid reservoir mounting bracket made from stainless steel.
Front showing. The Hydroboost is too close to the frame, the solution is to make the reservoir remote.
