11-22-2011, 05:39 PM
AR
Originally Posted by ERA Chas
Dan,
You may want to stage the rear carb at about 1/3rd of the front instead of 1/2. If you feel a flat spot during heavy throttle application, the rear carb needs to come in sooner.
Mine is set at about 20% of the lead carb but I have a lot of cam and 2.25" valves.
You should not feel anything except a strong, even pull of the RPM when properly staged.
OK - that is something else to look at. I'm guessing on the half throttle as about where the rear carb starts to open. I'll take a closer look at it and see if there is any adjustment in the linkage to play with.
Dan
