Compare the parts/pieces they use and price to other builders.......
A set of aluminum heads: what make??? are they Eldebrocks/Brodix or the chinese made patriot heads?????
an aluminum intake manifold: what make/type???? Same question as above?????
custom ground cam with muscle car chop??? WFT is that??? no cam specs!!!!!!!!
I'm not too impressed with the description of the parts they use, I would certainly want toknow exactly what type cylinders heads/intake/carb/cam and a lot of other things about the engine before I ordered one...
Just my .02 cents....
Just did a quick search and found a well known builder offering a similar engine,his makes 30hp more,uses Brodix or AFR heads,Ford Motorsports timing chain set-up and camshaft and hydraulic roller lifters,forged crank/H-beams rods,Edlebrock intake and top-of-the-line QuickFuel carb,basically all name brand top shelf parts,including break-in and dyno tune and it's $900.00 MORE....or you can have no-name heads/intake/cam/carb,cast crank and who knows what else internal parts and save 900 bucks (about 12% of the cost), choice is yours, I know which one I would choose.....
David
DAVID GAGNARD
