Tank Info
Russ
Getting ready to change my tank also. I didn't care for the bottom outlet. You can get a top port fitting that can be mod'ed to the tank. Go to Tanks, Inc and search their accessories. They have the top port and also a flange the same size as the fuel sender. You can drill the tank to accept it.
As far as mounting, you should either use the straps to allow it to be dropped at a later time; or weld the nuts to the steel bracket so you can remove the bolts without a wrench on the nut. That top side of the mounting bracket is not accessible when the body is installed
Paul
