Fred, l measured the engine intake for you in greater detail. Hope this helps more. First assume the engine is facing you with the water pump. To your right is the large rounded part of the upper intake. It is 11 inches right of the exact middle of the lower intake and 10.5 inches high from the serial number plate. To the left where the EGR is mounted it is 5 inches from the exact middle of the lower intake. The upper intake is 14 inches from front to rear and 16 inches right to left. The top of the upper intake starts 3.5 inches from the rear of the block and is centered at 10.5 inches from the rear of the block. The front of the upper intake is 7 inches from the middle of the intake looking at it from the EGR and 17.5 inches from the rear of the block. I tried to send a picture but not sure if it worked. If you need pictures you can email me at
Wilsonf@aol.com and I will send them directly. I could also use some advice regarding emisssions and what I need to complete the electronics on this engine if you have any. Thanks Frank
