I suspect it is too short to allow much rear suspension travel. You will have to mock it up or lay it out in AutoCAD and look at how much angle is put on the U-joints at the limits of suspension travel.
Since you have most components in place, I would mock it up and measure the expected angles. Then you can make an informed decision.
Dana recomends max 3 degrees working angle for the U-joints.
John
