Old 11-26-2011, 11:36 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Try to make the drive shaft at least as long as the lower control arms--it will be nec essary to limit suspension travel to the range that you can control rear axle housing angle change so as to stay within a +3-3 degree u joint angle with the transmission mainshaft.
