Old 11-26-2011, 01:00 PM
LodiWino LodiWino is offline
Cobra Make, Engine: ERA #773, 482 stroker, cross ram stack injection
Default Aluminum head steel bushings at header screws
When I unscrewed two header bolts, the threaded steel bushing in the aluminum head unscrewed and came out with the header bolt.
I can re-install the threaded steel bushing by making a shoulder screw to re-install them. Is this the correct procedure?
Should high temp Lock Tight be used to prevent the bushing from unscrewing again?
Drink no wine before its time
