Old 11-28-2011, 07:24 PM
tcrist tcrist is offline
I would say it is too long. Mine is only about 14" above the body. But that is not causing the down tube to intersect with the trunk compartment. Sounds as if the hoop is too far away from the door area. the down tube is supposed to fit just to the outside of the frame rail. I think DV has the measurments on the Capteddies build thread.
If you would like to, PM me with your e-mail address and I will send you a PDF file of the stock drivers side rollbar that I reverse engineered in cad.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
