Originally Posted by tcrist
Al,
The ones that I have seen that slide on have small brackets welded to each side and then have a spring between the brackets pulling the two together. Other wise you might get exhaust leaks between the two.
We went ahead and welded the tubes to the collectors. So what you see in the photos above is now one piece. We are also going to weld the 3 1/2" taperer reducer to the collector. I'm thinking of then using a V-band clamp between the reducer and muffler!
Dynatech 794-91230 - Dynatech V-Clamp Kits - Overview - SummitRacing.com
I'll get some photos tomorrow!
Al
I want to do right, Just not right NOW!
Reason: type-O
