If the fuel pump is running all the time with the key on and the injectors are firing wide open, along with all the relays clicking it sounds like your ECU is bad (the computer).
How is the A/C switch connected? Is it using the computer controls to cycle the A/C clutch? Are you using the A/C switch to give the ECU A/C line +12 volts or ground it?
