Old 12-09-2011, 12:59 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Sort of. The big issue is mass air vs. speed density. There's really no economical way to use a mass air meter with an 8 stack system. You could use a large plenum and feed that through a single meter - but what would be the point of that>
If you used an older speed density computer and a tuner you could probably make it work.
You might be better off using something like Megasquirt for that.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
