Old 12-11-2011, 12:49 PM
LodiWino LodiWino is offline
Cobra Make, Engine: ERA #773, 482 stroker, cross ram stack injection
Default 482 Fuel Line, fuel pump, regulator and injector specs.
I have an aluminum 482 set up for port injection. Motor should make 700+ HP.
Use: Sunday driver plus an occasional track day.
Fuel pump: Mallory 650-11106M 83 GPH @ 40 PSI
Regulator: Mallory 4305M 30-100 psi.
Injectors: Accel 110-050848 47.8 lbs/hr @ 43.5 psi
Fuel lines: ERA #773 with 3/8" hard line to fuel tank. -6 AN hose return line regulator to tank, -6 AN lines from fuel pump to regulator and fuel rails
Is this spec. going to work for the intended use?
Drink no wine before its time
