  #47 (permalink)
Old 12-13-2011, 04:47 AM
xb-60's Avatar
xb-60 xb-60 is offline
If I'm building the engine from the ground up, it will usually get internally balanced.
Blueprinting has nothing to do with balancing, it's part of the mock-up and assembly process.
A balance job will start at around $200 and can easily go past $400-500 if a lot of heavy metal needs to be added. The last Scat forged 351C rotating assembly that I did required 6 pieces of heavy metal, even with an I-beam rod and a Diamond piston. That added a huge amount to the balancing bill...
That sort of cost sounds reasonable to me.
Doesn't blueprinting involve selecting components, or adjusting components (as was seen in that You-Tube video, where the conrods were being ground) so that they are the same weight?
Glen
