  #26 (permalink)
Old 12-15-2011, 08:06 AM
Mike_I Mike_I is offline
Cobra Make, Engine: Midstates 427 / ERA 289 USRRC
Hi Mike, I use the Centroid sender unit. It is electronic with no moving parts so they actually read and work. Can you weld aluminum? Why don't I sell you a tank kit you assemble and leak check.
Hello Nick, I was curios if this sensor would work with the smiths fuel gauge that I had ordered. When I ordered the gauge I got the one for the GM fuel sender that I am currently using. According to Peter, there are a couple of different variations of the smiths gauge depending on which fuel sender will be used.
