Old 12-18-2011, 06:40 AM
boxhead's Avatar
boxhead boxhead is offline
Rob, I used a Commodore harness and ecu, modified to suit.
I deleted all the BCM items and anything else not needed, using the PDF it was fairly simple and I did it one Saturday arvo.
If you get a genuine harness from a wrecker I can send you a copy of PDF.
I found it easiest to pin it all to a large cardboard sheet and lay it out and label as I went, anything not needed was cut out.
Cruising in 5th
