Not Karl, but on first look at what appears to be the flange bolts on the trans pan, the flange appears to be parallel with the frame crossmember. This would initially suggest that the transmission may be level and the pan itself has an asymmetrical or cockeyed sump. However, on closer inspection, its not clear that those are actually pan bolts along the crossmember and the angle of the sides of the pan indicate that it is indeed canted to one side. I'm really curious to hear the real story on this.
Tropical Buzz
