Old 02-14-2002, 09:34 AM
Fred Fred is offline
Frank,
Thank you for all the dimensions. I will be out in the garage tonight measuring to see if I can make this work.
Regarding the electronics and emmissions, my neighbor is building an FFR kit and it is almost plug and go with the electrics and mustang harness. I converted from carb to EFI and am using a 94 -95 intake manifold because it fit under the hood that is controlled by the 89-93 A9L computer. I had to make a harness so everything works. It is not that complex. Once you have your kit and begin the wiring, me and all others with EFI will get you through it. If you have a specific question let me know.
Good luck
Fred
