Old 12-31-2011, 01:28 PM
marcalan's Avatar
marcalan marcalan is offline
Cobra Make, Engine: era 289 FIA #2112
The transmission has about 1200 - 1500 miles on a rebuild. About 8 months ago the transmission got locked out of gears. I re-aligned the shifter plates on the shifter using a .250 dowel pin per the manual. Without the car moving you can shift smoothly to all gears. With the car running, under load it seems to get get caught going from 2nd to 3rd. It does not grind, just like hitting a wall.
live for the moment or it may pass you by
