Sounds like bad blocking rings. You might try 'burnishing' them a little. with the car sitting still, engine running, clutch out(engaged) push against the gears that are giving you trouble. What you describe sounds like bad blocking rings but it could be a little gunk build up on them too. Of course do it in a safe spot in case it dumps into gear.
