indexing lakewood bellhousing
Hi Hammer thanks for the offer, but I went to Horbour Freight an bought one for 24 dollars. Had to modify it a little. I cut the shaft coming out of the magnetic base off to about 3 inches an took the grinder an cut two flatsides on it where I could bolt the dial indicator on where it would line up with the hole for the transmission. It worked perfect, I do need to get some of those dowels you mentioned. We got it to specs at +.005. It been out at lease .035 every since I had it. It never shifted good. They just bolted it on an did not check it, Maybe it will work better being indexed. Thanks again Flip If anybody wants a pic of my modified indexing tool let me know
