Originally Posted by RET_COP
Dana what happened to the 393? It would seem like that made at least 500HP.
Lou
The KC Brodix is a very nice head. the 210 would fit nice with a 427. The AFR also is a nice head.
Lou
In the short time I had the 393 on the road, it sure drove nice and seemed to make good power.
The shop that built the motor used the wrong camshaft thrust plate resulting in excessive endplay. The cam and distributor gear were wiped out in less that 175 miles. I saw that he tossed in some used pushrods when he built the motor so I figured I better check
everything. Crank, bearings, pistons and cylinder walls were undamaged. Measured all the clearances, CC'd the heads, etc. Everything checked out as per the build sheet.....except for the used, mismatched pushrods which were .080" too short, one of which was bent. That pretty much put me over the edge since by this time I had missed out on all the summer cruises, etc. I replaced all the damaged parts in the 393, a friend made me an offer on the motor to replace the 347 in his Mustang, so off it went.
