Just came back from the new years day ride, a little update. As Bill said, 1 - 3 shift no problem. Going from 2 - 3 would hit a wall, not all the time, just sometimes. Tried revving the motor as it happened, nothing. Tried shifting from 2 - 3 when I hit the wall by waiting a moment to de-torque the drive train, didn't work consistently. Had it going for a while where there was not problem shifting between the gears.
There is lube between the shifter plates. I took apart the shifter over the summer to make sure all was good. Also pulled off the top plate from the transmission and ran it through the gear so see what was going on and to make sure that there was fluid in the transmission case. At the time, I had jacked up the rear wheels so I could confirm I was in gear by spinning the tires.
live for the moment or it may pass you by
