Old 01-02-2012, 01:20 PM
GBowman's Avatar
GBowman GBowman is offline
Cobra Make, Engine: BDR #1230/B2 445CI SBF
Default Ford Racing 427 Alum block specs
Has anyone seen the actual specs on these crate engines? I've seen differing comp ratios (10.5:1 vs. 11:1) on different sites. There is plenty of info on the Iron block versions; however, the real data for the Alum blocks is hard to find. I have seen anywhere from 570 to 600 HP and 527 to 553 Ft Lbs???
Does anyone know someone with this set up? Thanks.
Gary Bowman
Voorhees NJ/Key Largo Fla/Ventnor NJ
