Old 01-02-2012, 06:31 PM
blykins blykins is offline
If you like where the engine peaks and you're not seeing any valve float issues, I would run similar durations but lift in the .600-.620" range.
Most of the aftermarket heads that you see really start to move some air at the .600-.650" lift range. It's good to select a camshaft that will work with the cylinder head design.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
