Thread: Gatlinburg
Old 01-04-2012, 06:48 PM
daverascal daverascal is offline
Cobra Make, Engine: acc
Default update
The body is on and the side pipe cut outs are done WOW do not ever want to do that again!!!! It is really starting to look like a car getting excited. I had to get a different radiator started out with a 28" wide which fits the bracket fine, then you set the body on no way. The inner fender well are molded into the front air dam. This is only 26" wide I talked to Joe about notching out so it would fit. He said it had never been tried and wasn't sure if the notching would affect the strength of the front end support. We talked about boxing in for support. I'm not into being a guinea pig, so I ordered a 26" today. I also checked on a rod run in Gatlinburg, April 12th through the 15th. I just wonder what the weather is like that time of year.
