Jeff it is looking good. Question about your bellhousing..Is it for a large or small flywheel and is it aluminum or iron. I have been working on my coupe and it will be no fun to get the engine and trans in and out. I think I will have to install the engine first and then the trans from the inside. Something else is the engine on your car centered in the frame or offset. On the coupe the engine is lowered 1 inch and offset 1 inch to the passenger side. Do you have the driveshaft yet. Is so how long is it . center to center of ujoint. They appear to be verry short.....6 to 8 inches. I kind of think I should have built a car similar to yours. I might have a hard time getting in and out of a coupe. Mark
