Bob, Where did you get the black vinyl that covers the window framework? I need to cut mine down 1/8 inch but will have to remove the black vinyl first. I bought a hardtop for mine and the passenger window will not fit. I had to remove the rubber molding on the botton of the hardtop and grind on the bottom of the hardtop for it to fit perfect. For what they charge for these hardtops they are junk! I have it fitting perfect now. Good thing I found the top 2nd hand but never used. Saved a bunch of money on buying it used cause they are very overpriced. The car numbers were very close also so it is the right top. Mark
