I have tried pepper and most of the other humane suggestions and had given up. My Cobra cover has a brown spot right in front of the windscreen where the cat likes to sit. As I was rummaging around in the garage I found some deer netting. It is a lightweight 1/2 mesh net. I decided to build a frame out of 3/4" PVC sprinkler tubing which was also stacked up in the corner of the garage. I built it to cover only from the front of the Cobra to the windscreen. I didn't glue the PVC together to keep it easy to break down in the summer if I don't need it.
