Thread: Rear End Steer
Old 01-09-2012, 02:38 PM
treblig treblig is offline
Cobra Make, Engine: Midstates in-work again
Default Rear End Steer
I have a ford 9” rear end. It is a tri bar design, lowers rods are straight to frame; uppers angle in from outside towards the brakes to the frame. The uppers are 9.400 inches long from center of bolt to bolt and the lowers are 12.700 long. I have hime joints at both ends on all radius rods. Everything is new no used parts.
My problem is when I get on the gas the car drives to the right and when you let up on the gas the cars goes to the left. Is my rear end moving side to side or do I have an alignment problem? Should I install bushed rod ends at one end of each radius rod?
Treblig
