Old 01-10-2012, 12:54 AM
alffie alffie is offline
Cobra Make, Engine: Classic Revival Kobra,LS7 427
Hi Mike
Go and buy a LS7 bellhousing they are 18mm longer!! I had the same problem when I bought my T56, Mal Wood stregthened my T56 for the LS7 but used a LS1 bellhousing and imput shaft. So when I rang him he was shocked!! So he sent me up a LS7 bellhousing and all bolted up fine, You may need to look at your spiggot bearing as the LS7 has a larger one installed in the first recess in the crank which is where most of the 18mm comes from so I had to remove it and fit a Holden V8 bronze spiggot to keep the imput shaft.
