Cheers Phil, the cone head bolts are break off bolts, the manufacturers use these as part of the anti theft, the bolt heads snap off when tightened up, thats why if you look close at the cones the centre will be rough.
Cheers for the advise on flipping over, it will be part of the strip and paint after Shelbyfest.
The in dash key, can I ask were you sourced this from?
I asked a local locksmith a while ago, he suggested a John Deere tractor switch & key.
Cruising in 5th
