looking at your frame layout I don't believe it has adaquet torsional stiffness and you will get severe torque steer with a car this light and a lot of hp & tq. You might be able to counter act some of it with some anti roll bars. Also , your drive shaft looks more like it might have 12-15 degrees at the u-joint.
You might also go to a much higher rate rear spring to stop some of the torque roll.and it seems as though maybe your trans crossmember is the most rearward cross member??????????
Reason: added comment about trans crossmember
