Thread: Rear End Steer
  #26 (permalink)
Old 01-11-2012, 01:07 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Dwight
I would like to see more pictures of his frame and for him to be a little more descriptive of how he checked from a hard point of the frame to where on the axle housing--
It appears to me in the pict that the frame is 2 x 4 tube and has absolutely nothing to add to torsional strenght behind the trans mount(and I can't even see that in the photo)
Yes his triangles are very small and change several degrees on any movement of the rear end in relation to frame. In fact they are more like an open sided polygon more than triangulated.
The Shell Vallies I have seen are a very little bit similar but the uppers are almost straight across so rear can't move sideways--they are so restrictive that there is very little drop of the rear when you lift the car.
