Kit Contents
So far, this is the inventory:
2 - Front Spring Tower Side
1 - Front Spring Tower Upper Center Plate
1 - Front Spring Tower Lower Center Plate
2 - Motor Mount - Top
4 - Motor Mount - Side
2 - Shock Tower
2 - Shock Mounting Brackets - Front
2 - Shock Mounting Brackets - Rear
2 - Rack and Pinion Mounting Bracket
8 - Front Control Arm Mounting Bracket
8 - Front Control Arm Mounting Bracket Reinforcement Triangle
1 - Rear Spring Tower Side - Front
1 - Rear Spring Tower Side - Rear
1 - Rear Spring Tower Center Plate
4 - Rear Control Arm Mounting Bracket
1 - Frame Rear End Cap
2 - Fuel Tank Support Tube Bracket
2 - Front Control Arm Sway Bar Bracket
2 - Rear Control Arm Sway Bar Bracket
--Mark
Reason: Added Stuff
