Old 01-19-2012, 06:08 AM
tamanaco's Avatar
tamanaco tamanaco is offline
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Default header gasket by Earl's performance products
My car had a set of earls performance products exhaust header gaskets. They also have parker pressure master p/n 29003a stamped on the aluminum gasket holder. I did some searching on google, didn't find any thing on this. It uses single rectangular gasket, that seem real soft, for each port, these are held in place by an aluminum plate about a 1/16 inch thick. This set up has worked flawless for the 6 years it's been on the car. I'd like to use this again on the stroke motor replacement. Anyone know if you can still find replacement gaskets?
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
