Thanks ICETOO - I drove about 90 ks today from Melb to Rye. I have turned off the power to the ECU for a while in case it fired up in a weird mode. I am also going to have a look at the MAf to make sure its clean as I read something about that. Also Can you disconnect O2s and run in Open loop mode to see if the O2s are giving false readings?
Thanks
rgds
Gregg
Reason: spelling
